Страница 1 от 2
Фотоволтаична инсталация
Публикувано: пон авг 11, 2008 5:46 pm
от r_stanev
Здравейте на всички интересуващи се. Нека да отворим нова тема за нещо навлизащо в българия и с очакващо голямо развитие за в бъдеще. Предполагам че има интерес.
Публикувано: пон авг 11, 2008 6:03 pm
от Spokoiniq
На прост български-що е то?
Публикувано: пон авг 11, 2008 8:50 pm
от romanpm
И как ще я правим сами :look: :prost: , щото тук нали е това направи сам ... :) /България не се ли пишеше с голяма буква/
Публикувано: ср авг 13, 2008 9:08 pm
от ssi
Лошото е ,че не виждам смисъл някой да си прави сам. Много гърч, за малко мощност.
Step 1 - Stain the Titanium Dioxide with the Natural Dye: Stain the white side of a titanium dioxide (TiO2) coated glass plate. This glass has been previously coated with a transparent conductive layer (SnO2), as well as a porous TiO2 film. Crush fresh (or frozen) blackberries, raspberries, pomegranate seeds, or red Hibiscus tea in a tablespoon of water. Soak the film for 5 minutes in this liquid to stain the film to a deep red-purple color. If both sides of the film are not uniformly stained, then put it back in the juice for 5 more minutes. Wash the film in ethanol and gently blot it dry with a tissue.
Step 2 - Coat the Counter Electrode: The solar cell needs both a positive and a negative plate to function. The positive electrode is called the counter electrode and is created from a "conductive" SnO2 coated glass plate. A Volt - Ohm meter can be used to check which side of the glass is conductive. When scratched with a finger nail, it is the rough side. The "non-conductive" side is marked with a "+." Use a pencil lead to apply a thin graphite (catalytic carbon) layer to the conductive side of plate's surface.
Steps 3 & 4 - Add the Electrolyte and Assemble the Finished Solar Cell: The Iodide solution serves as the electrolyte in the solar cell to complete the circuit and regenerate the dye. Place the stained plate on the table so that the film side is up and place one or two drops of the iodide/iodine electrolyte solution on the stained portion of the film. Then place the counter electrode on top of the stained film so that the conductive side of the counter electrode is on top of the film. Use the two clips to hold the two electrodes together at the corner of the plates. Offset the glass plates so that the edges of each plate are exposed. These will serve as the contact points for the negative and positive electrodes so that you can extract electricity and test your cell. The output is approximately 0.43 V and 1 mA/cm2 when the cell is illuminated in full sun through the TiO2 side.
Публикувано: чет авг 14, 2008 8:49 am
от Vlad_g
Ще ви пусна едно простичко ръководство, за това как да си направите функциониращ и ефективен пв-панел с прости и достъпни материали/ех, че реклама, а?/. Само да намеря файла :ops:
Ще Ви трябва доста време, а има и някой чаркалаци за майстор-експерти :wallbash:
Е, всичко може да се купи, разбира се. Най-малкия панел ти е 299 евро /има и екстра: с доставката/ за 60 вата.
Ей такива ми ти работи :lol:
Публикувано: чет авг 14, 2008 11:29 am
от romanpm
ssi
Съгласен съм с теб от много години :talk: не си струва усилията :skeptisch:
Публикувано: пет сеп 12, 2008 11:29 am
от g_ker
Vlad_g написа:
Колеги,какъв е размера на тези най-малките волтаици за 60 вата.
Публикувано: пет сеп 12, 2008 11:52 pm
от Master_Kenobi
Около 1 (1,2) х 2 (2,5) метра, ако не се лъжа.
Публикувано: ср сеп 17, 2008 10:42 pm
от Vlad_g
500 см. на 800 см., ама всъщност няма значение. Така или иначе е много скъпо без субсидия. Ясно Ви е, че субсидии ще видим през криффф макарон. Просто не мога да Ви опиша колко много ме е яд на това положение. Няма пари, няма подкрепа, че и ти пречат на всичкото отгоре.
Публикувано: чет сеп 18, 2008 9:25 pm
от tinalex
Vlad_g написа:
Колега,ако знаеш колко си прав.Но има и друго.Вместо да се хвърлят милиони за разработка на плоски телевизори,да бяха разработили фотоволтаичните панели.Досега щяхя да струват поне 5 пъти по-евтино.Но липсата на акъл и интереса ходят по всички,не само по българите.
