petromaniq - специалист
Пералнята показва код за грешка F03 & F08 и не работи. Моля за съвет!
2betrendy - специалист
не съм специалист, само ще ти напиша какво намерих в нета по въпроса.
F08
- някакво нагреваемо реле или по-точно нагревателя е развален и трябва да се смени електрониката на пералнята
F03
- термостата е направил проблем
Indesit washing machine error code 3 (F03)
On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault – check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
(http://www.whitegoodshelp.co.uk/wordpre ... ode-3-f03/)
Virtuozo - специалист
Значи гуугъл казва и то на няколко места че и двете грешки са относно температурата.
грешка 8 се отнася за релето на нагревателя
за грешка 3 пише това-, F-03 means that the NTC (Negative Tempature Co-efficient) is open or short circuit . And in English that means the device that regulates the water temp is either faulty or the wiring has come off . This device is attched to the heat element at the back of machine (depening on the age of the machine). check for loose wires . failling that you may need and new control board.
П-П Колегата ме е изпреварил,но се оказва че и той е на същата следа,което насочва на там.
Благодаря на всички отзовали се! И аз намерих в гугъл през това време обяснения на български.
Оказа се овлажняла електроника. След подсушаването на конекторите и най-вече на този на термодатчика (намиращ се на фланеца на нагервателя) всичко си дойде на мястото.
Тема "Проблем с пералня Indesit Evolution 1200WE125" | Включи се в дискусията:
