Uninstall WGA Notifications Manually
Log on to the computer by using an account that has administrative permissions.
Make sure that the WGA Notifications version that exists on the computer is a pilot version that range from 1.5.0527.0 to 1.5.0532.2 (Note: other versions should works too). To find the WGA Notifications version, follow these steps:
Click Start, and then click Control Panel.
Double-click Add or uninstall Programs, locate and then click Windows Genuine Advantage Notifications, and then click Click here for support information.
In the Support Info dialog box, verify the version number, and then click Close.
Rename the following files by changing the extension to .old:
Rename %Windir%\system32\WgaLogon.dll to %Windir%\system32\WgaLogon.old
Rename %Windir%\system32\WgaTray.exe to %Windir%\system32\WgaTray.old
Restart the computer.
Unregister LegitCheckControl.dll by using Regsvr32 with these steps:
Click Start, click Run, type cmd, and then click OK.
At the command prompt, type the following, and then press ENTER:
Regsvr32 %Windir%\system32\LegitCheckControl.dll /u
At the command prompt, delete the following files by typing the Del command and follow by pressing ENTER after you type each command.
Del %Windir%\system32\wgalogon.dll
Del %Windir%\system32\WgaTray.exe
Del %Windir%\system32\LegitCheckControl.dll
At the command prompt, type regedit.
Locate and then right-click the following registry subkeys. Click Delete after you locate each subkey.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\ CurrentVersion\Winlogon\Notify\WgaLogon
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows \CurrentVersion\removeremove\WgaNotify
