От няколко дена ми се върти един лаптоп в главата, понеже са го пуснали на промоция, но не мога да реша дали си заслужава, понеже пък не ми е много належащо.
Някой има ли мнение? Заслужава ли си? Най-вече за видеокартата, защото нищо не ми говори.
Dell Inspiron 15.6" Touchscreen Laptop I5559-6680SL, Intel Core i7-6500U Processor, 8GB Memory, 1TB Hard Drive, 4GB AMD Radeon R5 M335 4DDR3 Graphics, Windows 10
Specifications
Processor and Memory
Hard Drive and Multimedia Drives
Processor Type: 6th Generation Intel Core i7-6500U Processor (4M Cache, up to 3.10 GHz)
Processor Speed: 3.10ghz
Cache: 4MB
Memory (RAM): 8GB Dual Channel DDR3L 1600MHz (4GBx2)
Maximum Memory Expansion: Not Specified
Graphics and Audio
Hard Drive: 1TB 5.4k HDD
Optical Drive: Tray load DVD Drive (Reads and Writes to DVD/CD)
Multimedia Card Slot: 3-in-1 Media Card Reader and USB 3.0
Display, Keyboard, Mouse, and Webcam
Graphics: AMD Radeon R5 M335 4GB DDR3
Audio: Stereo speakers + MaxxAudio
Connectivity
Ethernet:0
Display Size: 15.6 inch LED Backlit On-cell Touch Display with Truelife and HD resolution (1366 x 768)
Display Type: LED
Display Resolution: 1366x768
Keyboard: Backlit Keyboard - English
Mouse: Touch Pad
Webcam: HD Cam
Ports/Slots
Wi-Fi: Intel 3160AC + BT4.0
Bluetooth: BT 4.0
Modem: N/A
Power
Ports: HDMI 1.4a (1), USB 3.0 (1), USB 2.0 (2), Kensington Lock slot, MCR (SD, SDHC, SDXC)
Software
Battery Type: 40 WHr, 4-Cell Battery (removable)
Typical Battery Life: Up to 8 hours of battery life: Based on testing using the Mobile Mark 2014 battery life benchmark test. For more information about this benchmark test, visit www.bapco.com. Test results should be used only to compare one product with another and are not a guarantee you will experience the same battery life. Battery life may be significantly less than the test results and varies depending on your product’s configuration, software, usage, operating conditions, power management settings and other factors. Maximum battery life will decrease with time and use.
AC Adapter: yes
Physical Specifications
Operating System: WinHome HighEnd 10 64 ENG
Manufacturer Software: Windows
Other Software: McAfee CB LiveSafe 30Day Trial
Trial Software: MS Office Trial TOPK, MUI (OTRT13M)
Specifications
Cache: 4MB
Graphics and Audio
Connectivity
Ethernet:0
Display Type: LED
Mouse: Touch Pad
Webcam: HD Cam
Ports/Slots
Bluetooth: BT 4.0
Modem: N/A
Power
Software
AC Adapter: yes
