  • 16
Тук ще бъдат премествани, мненията и темите преди да бъдат изтрити окончателно.
BLUEPUPIL - майстор
Щом толкова искаш знак СЕ на кабела
или придружаващата го документация,
то трябва да спазваш най-важното
условие след механичното нараняване,
а именно радиуса на огъване.
The intent of the CE Code is to prevent cable
damage by over-bending, but its generic
nature requires installers to look deeper
into the topic.
Cable bending radius limitations are mainly
affected by conductor size, insulation thickness,
number of conductors, and shielding / armour
type. Most stated bend radius values are for
statically installed cables which become even
more critical when the cables are installed
under tension. Industry standards like IEEE
1185 provide general cable information, CE
Code rules provide code requirements, and
manufacturer spec sheets provide cable-
specific requirements. All should be
considered in your project.
Understanding cable bend radii can help
jobsite installations. Over-bending cables
may damage the jacket, armour, and/or
insulation, reducing cable life. Using too
large a bend radius can result in higher
cable tray costs.
CE Rules for Bend Radii
Below are some of the main CE Code
bend radii rules for power and control cables.
12-110 Radii of Bends in insulated conductors
and cables
– “The radii of bends in insulated
conductors and cables shall be sufficiently
large to ensure that no damage is done to
the conductors
or cables or to their insulation,
covering, or sheathing.” This is a general rule
that applies to all conductor / cable types.
Additional code rules provide further
requirements for specific cable types.
Жалък неграмотник с мания за
разкомлексиране.
Аууууууууууу!
Нямате нужните права за да преглеждате прикачените към това мнение файлове.
вт юни 11, 2024 4:21 pmBLUEPUPIL написа:
С какво?
Некадърник, не е твоя работа.
Ай ся бягай при мама да те нашляпа...
BLUEPUPIL - майстор
BLUEPUPIL - майстор
ср юни 12, 2024 3:06 pmBLUEPUPIL написа:
Алоооо.....Уууу, смешника на форума.
Купи си преносим климатик:
вт юни 11, 2024 8:00 pmramona6300 написа:
Разпродажба!!!! Преносимият мини климатик охлажда, овлажнява и освежава.
На теб от особена полза ще е овлажняването... :lol:
P.S. МОЛЯ никой да НЕ ОБРЪЩА внимание на постовете на BLUEPUPIL
Той е напълно НЕКОМПЕТЕНТЕН по ЕЛЕКТРОТЕХНИКА и глупостите дето дараска може само да ви НАВРЕДЯТ.
Просто едно тъпо и заоблено парче.
Същият няма абсолютно никакво образование и познания по електротехника.
Просто ... ТРОЛ.
Ай ся блуе, бегай да с пиеш хапчетата и да се Увлажняваш... некадърник...
Кому е нужно да се поства асортимента на разни поизводители?!
На топикстартера присъждам рицарско звание PINKPUPIL.
Ето че BLUEPUPIL освен долен ЛЪЖЕЦ (доказано не еднократно) е и МНОГО ОПАСЕН с тъпите си постове.
Всичкото което показва тоя необразован некадърник са евтини китайски конектори.
Те НЕ ОТГОВАРЯТ на заявените параметри. Моля не слушайте ГЛУПАКА BLUEPUPIL и не използвайте такива конектори за нищо отговорно.
А най-добре - въобще не ги използвайте.
Показаните от малоумника BLUEPUPIL не могат да издържат не 32А ами и 16А не могат да издържат...
Бах ти и дрисльото... ЩЕ ВКАРА НЯКОЙ В БЕЛЯ.
ср юни 12, 2024 3:05 pmBLUEPUPIL написа:
BLUEPUPIL - майстор
ср юни 12, 2024 8:12 pmhidrazin написа:
Ама влезе доброволно в капана.
Нали искаше да имат СЕ.
Имат и то от EU лаборатория.
Има и 63А за гъзоръчковци, като сбърканото
хомо. Иди да ги туриш на кака Гинка, да
паснат на 10мм2 кабели, дето и препоръча
за кухнята. Докопаш ли някой, будала
нямаш милост.
Алчна гадинка!
Кака Гинка ще прелисти темата и ще
ти набие със страшна сила шут, знаеш
вече къде, в увисналия..........
Чееееееееееебурашка, гей парада още
не е почнал, 60 страници се гъзиш, ама
си объркал и темата и форума.
Егати злобното ЛГБТ.
:lol:
чет юни 13, 2024 12:16 amBLUEPUPIL написа:
Имат ама друг път. Ако някоя EU лаборатория им е издала СЕ - да ти е...а и джендърската лаборатория. :lol:
Я си виж тъпата картинка и какво пише не нея.
Power Rating: 7KM
К'во е т'ва бе некадърник? Километри ли? :lol: :lol: :lol:
Точно това различава специалистите от глупаци като BLUEPUPIL - могат да четат, разбират и могат да "помиришат" ментетата.
Ментета като теб Блуе. Хората са експерти а ти си полски свирач... И такъв ще си останеш завинаги.
Ето ти и адреса на производителя - Yueqing Economic Development Zone,Zhejiang Wenzhou,325600,CN
И ако му поискаш СЕ ..... НЯМА да ти даде такъв. :lol:
Блуе, ти НИКОГА няма да можеш да даваш компетентно мнение в областта на електротехниката.
НИКОГА !!! Толкова ли е трудно да разбереш че там си и ще си останеш само един ревящ тъпчо?
Ай ся бегай при мама да те нашляпа... :rock:
BLUEPUPIL - майстор
чет юни 13, 2024 9:59 amhidrazin написа:
Номер едно производител, какво дума?
20А
2.5мм2
Въйййййййййй!
Знаеш процедурата!
Измерваш се и си правиш протокол.
После даваш омовете от измерването на
изолацията на шнуровете, да се посмеем на
числото, защото ще е със стойност, характерна
за някоя друга галактика.
Бегай да лъжеш кака Гинка!
И да прецакваш на някой ел.
инсталацията на "приемлива"
цена.
:lol:
  • 16
Тема "спам - Как да си направя ел. инсталацията?" | Включи се в дискусията:
