nikrum написа:0. Fuel ignition timeout --> [25]minНикрум мерси за параметрите тая вечер ще пробвам с тези обаче при мене пар 51е 115
1. Ignition test timeout --> [10]min
2. Fuel type --> [0]
3. Heat up feeder OFF time --> [150]
4. Heat up feeder ON time --> [150]
5. Fuel ignition feeder 1 OFF time --> [120]
6. Fuel ignition feeder 1 ON time --> [25]
7. Ignition test feeder 1 OFF time --> [120]
8. Ignition test feeder 1 ON time --> [10]
10. Power 1 feeder 1 ON time --> [19]
18. Power 5 feeder 1 ON time --> [63]
19. Stop fire fan 1 speed --> [240]
20. Test fire fan 1 speed --> [140]
21. Heat up fan 1 speed --> [150]
22. Fuel ignition fan 1 speed --> [170]
23. Ignition test fan 1 speed --> [180]
24. Power 1 fan 1 speed --> [150]
28. Power 5 fan 1 speed --> [200]
50. Cool fluid exit temp. diff. --> [10]
51. air temperature --> [51.0]
52. Water temperature in stove mode --> [52]
53. Cool fluid entry temp. diff. --> [0]
54. Ignition test gases temperature --> [45]
55. Modulation start gases temperature --> [65]
59. No fuel (error) gases temperature --> [49]
60. Fan 1 blow cleaning period --> [60]min
61. Fan 1 blow cleaning duration --> [35]s
62. Fan 1 blow cleaning speed --> [245]
67. Water Pump ON temperature --> [40]
68. Water Pump OFF temp. --> [35]
70. Heat up duration --> [150]
71. Fuel ignition temp. check samples --> [6]
72. Fuel ignition temperature rise --> [2]
76. Selected configuration --> [2]
92. Pellets quality --> [1]
93. Wood quality --> [1]
94. Time to service --> [0]
95. Stove cool fluid entry temp. diff. --> [10]
96. Stove cool fluid exit temp. diff. --> [10]
97. T1-T2 for min. modul. speed --> [0]
101. Blow out duration --> [180]
П55-65 колко градуси означава тва и пар72-2 начи отказ е тва за вътр термостат
