Имам пералня whirlpool AWM 8125 която даде грешка F09 и понякога грешка FA.Ненормалното е, че при първоначално избиране на програма веднага се включва помпата за изхвърляне на водата.В следващия момент се опитва да пусне студена вода, но спира и дава грешка F09.Има случаи в които светва и червен диод, че липсва налягане на входа на водата.
Моля ако някой знае какъв е проблема да пише.Благодаря.
С поздрав : Пламен
Gladiator_BG - специалист
http://www.fixya.com/support/t513562-er ... duet_front
малко на долу са дали решението на проблема ...
ако тръгна да го превеждам мога само да те объркам ... някой с по добър английски може да свърши тази услуга :wink:
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
още малко инфо от друг форум
F9 is a water pump problem, either clogged pump, or pump malfunctioning, Check for something clogging the water pump. To do that open the lower access panel by unscrewing the 3 torx screws at the very bottom of that panel, then you will see the plastic water pump in the middle front, just unscrew the handle, get a few dry towels as some water will come out.
lenko71 - специалист
Става въпрос за помпата дето ихвърля водата. Отвори филтъра (на помпата) и го почисти. Предполагам имаш книжка където е описано къде се намира и как се отваря
Благодаря ви приятели.Ще проверя това което сте ми изпратили и дано успея с ремонта.
Още вначалото проверих всички филтри както на изхода така и на входа на водата-всичко беше наред.
С поздрав : Пламен
sasooooooooo - "специалист"
"F09" е Overflow Състояние грешка. Това обикновено се дължи на неизправност налягане превключвател, хлабав или счупен конектор между Pressure Switch, Канализация помпа и централизиран контрол звено (ЦКЗ), или ... "изтичането на помпа или изтичане на линия, което е станало запушена.
Тъй като този проблем се появява периодично по време на цикъла на измиване, щях да проверите филтъра изтичане на помпа за първи препятствия. Тя може да бъде, че сте отломки, подадена в помпата не го кара да се отцеди добре. За достъп до помпа:
1. Изключете миене.
2. Премахване на долния панел ритник по вратата чрез премахване на винта под долния ръб. Съвет: Поставяне на няколко пресечки от дървен материал под предните крака на миене ще направи много по-лесен достъп.
3. На изтичането на помпа се намира под корито за пране в центъра. Съвет: Ако сте собственик на магазин VAC, премахване на линия изтичане на standpipe в стената и дръпнете вакуум чрез изтичане на линия. Това ще премахне всички остатъчни вода от миене и да чисти по-късно много по-малко разхвърлян. Сега, отстранете капачето на изтичане на помпа и премахнете. Изчиствам на помпата филтър и проверка на помпата ротор за препятствия.
Ако не притежавате VAC магазин, място куп кърпи около изтичане на помпата преди да го отворите. Има за галон, или на водата във ваната, ред и изтичане на помпата.
Опитайте това от една страна, и да ме уведомите, ако това ви поправя проблема. Ако не, може да се наложи да се провери налягането ключа и окабеляване. Надявам се това да ви помогне.
F9 е проблем, водна помпа, или запушена помпа, помпа или неизправност, проверете за нещо, запушване на водна помпа. За да направите това отвори по-ниски панел за достъп до unscrewing на 3 TORX винтове в самото подножие на този панел, тогава ще видите на пластмасови изпомпване на вода в средата часа, просто развийте дръжка, да вземем няколко сухи кърпи, тъй като някои вода ще се вън.
Превод: Гугъл
sasooooooooo написа:
1. Изключете миене.
Превод: Гугъл
:lol: :lol: :lol: :lol: :lol:
гуглето го превежда като бултрата ... супер "дървено"
Благодаря за превода.
Аз също стигнах до същите заключения. Ето защо обърнах внимание на всички конектори и ел. връзки без да пипам нищо друго.
В момента пералнята работи и не дава грешка. Дано това да е била причината.
Благодаря на всички още веднъж.С поздрав : Пламен
Gladiator, Гугула много умен, а? Превежда с български манталитет :lol:
Имах същият проблем. F09 или FA ше рече препълване или преливане. Трябва ръчно да изпомпаш водата през маркуча. Ако и след това не стане обади се на момчетата в сервиза. Телефона мисля че беше 931 12 33.
Тема "Пералня whirlpool" | Включи се в дискусията:
