  • 26
  • 27
  • 28
  • 29
  • 30
  • 403
LazarGanev - "Велик майстор"
МОЛБА
от Лаврен Йозов Барбов, служител на околийска болница с. Ген. Николаево, Пловдивско
О Л Б А II-1.jpg (95.49 KиБ) Видяна 5282 пъти
Последна промяна от LazarGanev на нед фев 17, 2008 6:48 pm, променено общо 1 път.
8180 - майстор
Dear Tech Support:
Last year I upgraded from Girlfriend 7.0 to Wife 1.0. I soon noticed that the new program began unexpected child processing that took up a lot of space and valuable resources.
In addition, Wife 1.0 installed itself into all other programs and now monitors all other system activity. Applications such as Poker Night 10.3, Football 5.0 , Hunting and Fishing 7.5 , and Golf 3.6 were also affected .
I can't seem to keep Wife 1.0 in the background while attempting to run my favorite applications. I'm thinking about going back to Girlfriend 7.0 , but the uninstall doesn't work on Wife 1.0 Please help!
Thanks,
Troubled User.....
_____________________________________
REPLY:
Dear Troubled User:
This is a very common problem that men complain about.
Many people upgrade from Girlfriend 7.0 to Wife 1.0, thinking that it is just a Utilities and Entertainment program. Wife 1.0 is an OPERATING SYSTEM and is designed by its Creator to run EVERYTHING!!! It is also impossible to delete Wife 1.0 and to return to Girlfriend 7.0 . It is impossible to uninstall, or purge the program files from the system once installed.
You cannot go back to Girlfriend 7.0 because Wife 1.0 is designed to not allow this. Look in your Wife 1.0 manual under Warnings-Alimony/Child Support. I recommend that you keep Wife 1.0 and work on improving the situation. I suggest installing the background application 'Yes Dear' to alleviate software augmentation.
The best course of action is to enter the command C:\APOLOGIZE! because ultimately you will have to give the APOLOGIZE command before the system will return to normal anyway.
Wife 1.0 is a great program, but it tends to be very high maintenance . Wife 1.0 comes with several support programs, such as Clean and Sweep 3.0 , Cook It 1.5 and Do Bills 4.2 .
However, be very careful how you use these programs. Improper use will cause the system to launch the program Nag Nag 9.5 . Once this happens, the only way to improve the performance of Wife 1.0 is to purchase additional software. I recommend Flowers 2.1 and Diamonds 5.0 !
WARNING!!! DO NOT, under any circumstances, install Secretary With Short Skirt 3.3 This application is not supported by Wife 1.0< /SPAN> and will cause irreversible damage to the operating system and can delete all bank account information!
Best of luck,
Tech Support
Justy - майстор
Командир пилотът помолил своя позната да замени разболялата се стюардеса.
" Сега обяви излитането " подсказва и той.
Дамата взима микрофона:
" Уважаеми пътници, уведомявам ви, че след малко г-н Иванов ще вдигне самолета във въздуха "
Полетът протекъл тежко...
marc - специалист
Мъж седи на спирката на трамвая и се заглежда по стоящата до него красавица. Решава да я заговори, но не знае как. По едно време се обръща към нея и пита:
- Извинете, тука номер 10, минава ли?
- Минава.
- А номер 12, минава ли?
- Минава.
- А, номер...
- Вижте какво! - прекъсва го девойката. Оттук минават всички номера, обаче вашият няма да мине...
marc - специалист
Стопаджийка спира шофьор на камион и пита:
- Може ли да ме закарате до Варна?
- Разбира се! Не отказвам на бременни жени.
- Но, аз не съм бременна!
- Е, до Варна има много път...
marc - специалист
Две баскетболистки си говорят:
- Ти какви противозачатъчни ползваш?
- Табуретка.
- Моят приятел е дребен и когато правим секс, той се качва на табуретката. Аз го гледам в очите - започне ли да ги бели, ритам табуретката.
marc - специалист
В цирка водещия излиза и обявява:
-Дами и господа, сега ще видите дресировка.
Един от първия ред става и крещи със все сила- Мошенници!
Водещият се смутил, но дресьорите излязли и си изпълнили номера.
Излиза пак водещия:
-Дами и господа, сега ще видите въздушна акробатика.
Онзи от първия ред пак става и крещи със все сила- Мошенници!
Водещия много се ядосал, но излязли акробатите и си изпълнили номера.
Излиза пак водещия и обявява:
-Дами и господа, сега ще видите смъртно опасен номер, свободен полет от купола на цирка без предпазни средства.
Угасват светлините, чува се дроб на барабани и в тъмнината вик:
-Мошенници, къде ме вдигате мамка ви!
marc - специалист
ха ха ха
Майстор прави ремонт. Застила кухнята с балатум. Вече попривършил решава да изпуши цигара. Тук цигарите, там цигарите, няма ги. Гледа по една време голяма подутина в центъра на балатума.
"Значи там съм ги забравил"-мисли си. "Няма сега да вдигам целия балатум и всичко наново". Взима един чук и чук-чук-чук отгоре....чука докато всичко се изравнило. Доволен сяда и се наслаждава на работата.
Влиза стопанката:
-Забравихте си цигарите в стаята, его ви ги. А тук хамстерчето ми се разхождаше, да сте го виждали?
:-D :-D :-D
marc - специалист
Влиза в бара мъж и от вратата вика- Барман, 22-ри коктейл!
Бармана налива, глътва го мъжа набързо и започва да прикляка, издава възгласи..ху-ха, аху! Скача, подскача, кляка става...
Тълпата го наблюдава смаяно.
Мъжът се провиква- Барман, още един 22-ри коктейл. Глътва го отново и още по енергично подскача и прикляка.
Трети път провиква- барман, пак 22-ри. Ху-ха,..размахва ръце...
Тълпата замряла и го наблюдава смаяно. Адски възбуден мъжът си тръгнал. Приближава се човек до бара и вика, абе барман, дай да го видим този 22-ри коктейл!
Дал му бармана, глътнал го човека.
- И какво пък толкова бе бармане? Коктейл като коктейл...
- Абе де да знам...Сигурно защото струва 600 долара.
marc - специалист
-Скъпи, аз имам нужда и от внимание, не
само от секс - казва жена на съпруга си.
-Внимание! Ще правим секс!
  • 26
  • 27
  • 28
  • 29
  • 30
  • 403
Тема "Вицове" | Включи се в дискусията:
