Колеги добре дошли в клуба
Така щом имаш кода можеш ли да ми кажеш настройките ти в момента ето ти листа с параметри ти го попълни:
n-8-1 Type pellet
n-8-1-01 Load pelet -
n-8-2 Tupe Chimney
n-8-2-01 Ecxaust Chimney -
n-8-3 Bank Data 00
n-8-4 Settings General
n-8-4-01 Halt Restart -
n-8-4-02 Asp-Min Spento -
n-8-4-03 Preload Light -
n-8-4-04 Waiting Fire -
n-8-4-05 Exh-Spee Preload -
n-8-4-06 Differen Off Auto -
n-8-4-07 Del-off Auto -
n-8-4-08 Change Output -
n-8-4-09 Exchang Cleaning -
n-8-4-10 Frozen Keybord -
n-8-4-11 Black Out -
n-8-4-12 Time Service -
n-8-4-13 Modo Stand-By -
n-8-5 Test Outpust
n-8-6 Settings Factory
n-8-6-01 Minutes Time Out -
n-8-6-02 Minuti Start -
n-8-9-03 Cadence Cleaning -
n-8-6-04 Auger Light -
n-8-6-05 Coclea Start -
n-8-6-06 Coclea Pover1 -
n-8-6-07 Coclea Pover2-
n-8-6-08 Coclea Pover3 -
n-8-6-09 Coclea Pover4 -
n-8-6-10 Coclea Pover5 -
n-8-6-11 Dely Alarm -
n-8-6-12 Duration Cleaning -
n-8-6-13 Threshol Minimum -
n-8-6-14 Threshol Maximum-
n-8-6-15 Thresol Blower -
n-8-6-16 Exhaust En-Start -
n-8-6-17 Exhaust Engi-Avv -
n-8-6-18 Exhaust Engine1 -
n-8-6-19 Exhaust Engine2 -
n-8-6-20 Exhaust Engine3 -
n-8-6-21 Exhaust Engine4 -
n-8-6-22 Exhaust Engine5 -
n-8-6-23 Encoder -
n-8-6-24 Time Breaking -
n-8-6-25 Treshol Pump -
n-8-6-26 Exclued Pressure-
n-8-6-27 Treshol Pression -
n-8-6-28 Treshol OFF -
n-8-6-29 Exh-Spee Cleaning -
n-8-6-30 Auger Cleaning -
n-8-6-31 Speed Blow1 -
n-8-6-32 speed Blow2 -
n-8-6-33 Speed Blow3 -
n-8-6-34 Speed Blow4 -
n-8-6-35 Speed Blow5 -
n-8-7 Reset Par-Time
n-8-8 Reset Alarm
n-8-9 Memory Counters
Пиши и ще коментираме
n-8-1 Type pellet
n-8-2 Tupe Chimney
n-8-3 Bank Data 00
n-8-5 Test Outpust
n-8-6-23 Encoder -
n-8-8 Reset Alarm
